BHSY Posted May 7, 2025 Posted May 7, 2025 Hi @Fiery I want to inform you that I updated the AIDA64 to 7.65.7415 beta and encountered a file export issue. Both from Net Update and the Beta file downloaded from your website. After I export my old sensor panel file as spzip, I import my other older file. When I want to import the spzip file, nothing happens. I tried to rename the spzip to zip file so that I could try to unzip the file but it prompts an error, 'The archive is corrupt'. Saving the file in .sensorpanel also wouldn't work. The keyboard shortcut Alt-arrow for the directional button works very well. So far, I haven't encountered other issues except for the spzip file. If the spzip file issue is resolved, can you implement 2 types of files for saving, .sensorpanel and .spzip? Quote
Fiery Posted May 7, 2025 Posted May 7, 2025 56 minutes ago, BHSY said: Hi @Fiery I want to inform you that I updated the AIDA64 to 7.65.7415 beta and encountered a file export issue. Both from Net Update and the Beta file downloaded from your website. After I export my sensor panel file as spzip, I import my older file. When I want to reopen the spzip file, nothing happens. I tried to rename the spzip to zip file so that I could try to unzip the file but it prompts an error, 'The archive is corrupt'. Saving the file in .sensorpanel also wouldn't work. The keyboard shortcut Alt-arrow for the directional button works very well. So far, I haven't encountered other issues except for the spzip file. If the spzip file issue is resolved, can you implement 2 types of files for saving, .sensorpanel and .spzip? Please send me the layout that fails to be exported to SPZIP in email, exported to a .sensorpanel file by the previous stable or beta version. Quote
Fiery Posted May 8, 2025 Posted May 8, 2025 18 hours ago, BHSY said: Hi @Fiery I want to inform you that I updated the AIDA64 to 7.65.7415 beta and encountered a file export issue. Both from Net Update and the Beta file downloaded from your website. After I export my old sensor panel file as spzip, I import my other older file. When I want to import the spzip file, nothing happens. I tried to rename the spzip to zip file so that I could try to unzip the file but it prompts an error, 'The archive is corrupt'. Saving the file in .sensorpanel also wouldn't work. The keyboard shortcut Alt-arrow for the directional button works very well. So far, I haven't encountered other issues except for the spzip file. If the spzip file issue is resolved, can you implement 2 types of files for saving, .sensorpanel and .spzip? Thank you for your help! The issue was that your layouts include several non-existent image files. We’ve fixed that up in the SPZIP export module in the latest AIDA64 beta update that will be rolled out later today. We’ve also reverted back to the classic .sensorpanel format export when you press the Export button just to stay on the safe side. SPZIP import/export may need some more time to mature. BTW, if you right-click on the Export button, you can choose between export file formats 😉 Please let us know if you find any issues importing or exporting using the SPZIP format. 1 Quote
BHSY Posted May 8, 2025 Author Posted May 8, 2025 5 minutes ago, Fiery said: Thank you for your help! The issue was that your layouts include several non-existent image files. We’ve fixed that up in the SPZIP export module in the latest AIDA64 beta update that will be rolled out later today. We’ve also reverted back to the classic .sensorpanel format export when you press the Export button just to stay on the safe side. SPZIP import/export may need some more time to mature. BTW, if you right-click on the Export button, you can choose between export file formats 😉 Please let us know if you find any issues importing or exporting using the SPZIP format. Thank you for the quick reply. Will the keyboard shortcut key for the directional button, the Alt-arrow key, still be included in the latest AIDA64 beta update? Also, right-clicking the mouse to bring up the shortcut menu was disabled. Will this be fixed too? Quote
Fiery Posted May 8, 2025 Posted May 8, 2025 10 minutes ago, BHSY said: Thank you for the quick reply. Will the keyboard shortcut key for the directional button, the Alt-arrow key, still be included in the latest AIDA64 beta update? Yes, of course. Quote Also, right-clicking the mouse to bring up the shortcut menu was disabled. Will this be fixed too? We haven't disabled that, but maybe you disabled it in AIDA64 / Preferences / Hardware Monitoring / SensorPanel ? Quote
BHSY Posted May 8, 2025 Author Posted May 8, 2025 I love using the Alt-arrow key to move the items. Thanks👍. 45 minutes ago, Fiery said: Yes, of course. We haven't disabled that, but maybe you disabled it in AIDA64 / Preferences / Hardware Monitoring / SensorPanel ? Oh yeah, I forgot about the 'enable the context menu'? So sorry. I must have accidentally disabled it😜. Thanks. Quote
BHSY Posted May 8, 2025 Author Posted May 8, 2025 19 minutes ago, BHSY said: I love using the Alt-arrow key to move the items. Thanks👍. Oh yeah, I forgot about the 'enable the context menu'? So sorry. I must have accidentally disabled it😜. Thanks. Correction. The 'enable the context menu' is to bring up the SensorPanel Manager, not for the sensor item(s). It's the sensor item(s) that I am unable to right-click to select the shortcut menu like edit, delete, or modify. Quote
Fiery Posted May 8, 2025 Posted May 8, 2025 4 minutes ago, BHSY said: Correction. The 'enable the context menu' is to bring up the SensorPanel Manager, not for the sensor item(s). It's the sensor item(s) that I am unable to right-click to select the shortcut menu like edit, delete, or modify. Thank you for your feedback. I’m not sure which place are you unable to use the right-click context menu. We’ve tried it on the SensorPanel itself, and it still works fine. Quote
BHSY Posted May 8, 2025 Author Posted May 8, 2025 4 minutes ago, Fiery said: Thank you for your feedback. I’m not sure which place are you unable to use the right-click context menu. We’ve tried it on the SensorPanel itself, and it still works fine. I've replied to you via email. Thanks. Quote
