Dav' Posted May 28, 2025 Posted May 28, 2025 Hi ! I'd like to use the "Δ" (upper case delta) on my sensor panel simple sensors but it's replaced by a "?". Please how can I achieve that ? Thanks ! Quote
Fiery Posted May 28, 2025 Posted May 28, 2025 2 minutes ago, Dav' said: Hi ! I'd like to use the "Δ" (upper case delta) on my sensor panel simple sensors but it's replaced by a "?". Please how can I achieve that ? Thanks ! The beta channel of AIDA64 will soon migrate to a brand new AIDA64 version that will support Unicode characters. I assume that will solve this issue too. Make sure to enable automatic updates to beta builds in AIDA64 / Preferences / General / NetUpdate / Update type / Stable and beta updates. Quote
Fiery Posted June 2, 2025 Posted June 2, 2025 On 5/30/2025 at 8:51 PM, Dav' said: Cool, thank you ! Beta updates activated👍 The above mentioned new beta build is now available for download: 2 Quote
