Chris77 Posted June 2, 2025 Posted June 2, 2025 Hello! After the update to 7.99 Beta version today, the pictured sensors are not showing anymore in AIDA64. Before Beta 7.99 there was no problem with sensor measurement. I am using an ASUS RTX 5090 Astral. Will there be a solution for this? Many thanks and best regards, Christian Quote
Fiery Posted June 2, 2025 Posted June 2, 2025 1 hour ago, Chris77 said: Hello! After the update to 7.99 Beta version today, the pictured sensors are not showing anymore in AIDA64. Before Beta 7.99 there was no problem with sensor measurement. I am using an ASUS RTX 5090 Astral. Will there be a solution for this? Many thanks and best regards, Christian In AIDA64 please press Ctrl+D --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Also press Ctrl+D --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Solution Fiery Posted June 3, 2025 Solution Posted June 3, 2025 17 hours ago, Chris77 said: Hello! After the update to 7.99 Beta version today, the pictured sensors are not showing anymore in AIDA64. Before Beta 7.99 there was no problem with sensor measurement. I am using an ASUS RTX 5090 Astral. Will there be a solution for this? Many thanks and best regards, Christian We've fixed the issue in the latest AIDA64 beta update available at: https://www.aida64.com/downloads/latesta64xebeta Let us know how it works. Quote
Chris77 Posted June 3, 2025 Author Posted June 3, 2025 Hello! Many thanks, now it works as before, without problems. 🙂 Quote
Fiery Posted June 3, 2025 Posted June 3, 2025 57 minutes ago, Chris77 said: Hello! Many thanks, now it works as before, without problems. 🙂 Thank you for your feedback! Quote
