Grimoire Posted Saturday at 12:45 AM Posted Saturday at 12:45 AM I am unable to see the per pin power monitoring in the sensors for my ASUS Astral 5090. Other hardware monitoring applications are able to see it. For example both HWINFO 64 shows it as well as GPU Tweak III. I would like to be able to add per pin power to my Sensor Panel. Is this something that can be added? Quote
Fiery Posted Saturday at 06:39 AM Posted Saturday at 06:39 AM 5 hours ago, Grimoire said: I am unable to see the per pin power monitoring in the sensors for my ASUS Astral 5090. Other hardware monitoring applications are able to see it. For example both HWINFO 64 shows it as well as GPU Tweak III. I would like to be able to add per pin power to my Sensor Panel. Is this something that can be added? Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. If it still doesn't work, then in AIDA64 please press Ctrl+D --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
Grimoire Posted Saturday at 08:53 AM Author Posted Saturday at 08:53 AM Thanks. I still don't have the per pin power sensors on the latest beta. I have attached the nVIDIA SMBus Dump to this post. nvidiasmbusdump.txt Quote
Fiery Posted Saturday at 09:07 AM Posted Saturday at 09:07 AM 11 minutes ago, Grimoire said: Thanks. I still don't have the per pin power sensors on the latest beta. I have attached the nVIDIA SMBus Dump to this post. nvidiasmbusdump.txt 9.44 kB · 1 download Thank you! This is a new Astral video card variant that AIDA64 doesn't recognize just yet. Please let us know the full model ID of your video card, e.g. ROG-ASTRAL-RTX5090-32G-GAMING. Quote
Grimoire Posted Saturday at 03:42 PM Author Posted Saturday at 03:42 PM It is listed as a ROG-ASTRAL-RTX5090-O32G-GAMING Quote
Fiery Posted 17 hours ago Posted 17 hours ago 20 hours ago, Grimoire said: It is listed as a ROG-ASTRAL-RTX5090-O32G-GAMING Thank you! Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote
Fiery Posted 14 hours ago Posted 14 hours ago 42 minutes ago, Grimoire said: This works now, thanks! Thank you four your feedback! 1 Quote
