Information in my BIOS indicates that I have system temperature available but it does not appear in the OSD Items. What do I need to do to be able to display the system temperature in the OSD? Thanks, John.
AIDA64 is supposed to detect 3 temperatures on your motherboard:
- PWM
- Chipset
- CPU
I suppose the PWM temperature may be the same that the BIOS Setup calls "System" temperature.
- PWM
- Chipset
- CPU
Fiery, thanks for your instant response. I do display the PWM temperature and it is somewhat lower than the CPU cores, but seems a little high for system. Right now my HDD temp is 24C and the PWM is 32C while the cores are running 40C. My room temp is 68F (20C). I will keep an eye on PWM temp and check my BIOS the next time I boot. Thanks and enjoy, John.
