s0.sunny Posted February 13, 2014 Share Posted February 13, 2014 Hi. We are considering a posibility to use AIDA BE in our company. not so long ago i tried to figure out how works remote control and monitoring. My question is how can i use remote monitoring function (or any of the rest) to monitor a few servers from the internet. I was able to establish a connection only with the one of with only one of them through standart port - 2346 (using port forwarding on the gateway). But I could not connect using forwarding from any others ports (like 95.47.182.101:2350 -> 192.168.05:2346). If there is any chance to configure remote monitoring this way? Quote Link to comment Share on other sites More sharing options...
Mice007 Posted February 14, 2014 Share Posted February 14, 2014 Hi, It should work without any special configurations. Just make sure you set the port numbers properly both in the router forwarding and in the client side AIDA64 Preferences where you want to start making connections. Also make sure there are no firewalls that may block inbound or outbound connections. Quote Link to comment Share on other sites More sharing options...
s0.sunny Posted February 17, 2014 Author Share Posted February 17, 2014 In the client side of AIDA64 we just made connections in "computer groups" windows like this: 94.228.255.110:2350 94.228.255.110:2351 94.228.255.110:2352 94.228.255.110:2353 And on the router was port forwarding rules: 2350->192.168.0.1:2346 2351->192.168.0.2:2346 2352->192.168.0.3:2346 2353->192.168.0.4:2346 But it didn't work. Quote Link to comment Share on other sites More sharing options...
Fanatic Posted September 18, 2014 Share Posted September 18, 2014 same problem too! Our network requires : server (any port for example 5674-5677) ----> router -----> port forwarding -----> port 5001 goes to PC1, port 5002 goes to PC2, port 5003 goes to PC3 etc. Quote Link to comment Share on other sites More sharing options...
Fanatic Posted September 29, 2014 Share Posted September 29, 2014 i want to buy this software if it works ! ! ! Quote Link to comment Share on other sites More sharing options...
