Slechtvalk Posted February 16, 2014 Posted February 16, 2014 Good Morning, after installing a second 7970 aida does not show the gpu sensor of the firslyt installed gpu which is now the "slave" card. If i change cards in slots its only shown the gpu temp sensor of the card in first pcie slot / mastercard. atismbusdump.txt atigpureg.txt Quote
zoomer-fodder Posted February 16, 2014 Posted February 16, 2014 in load second gpu sensor will show in aida64 without load works ZeroCore and shutdown secong gpu with his coolers, Quote
Fiery Posted February 16, 2014 Posted February 16, 2014 You need to disable ULPS to make AIDA64 recognize and handle both your GPUs properly. You can disable ULPS by scanning the Registry (using e.g. REGEDIT.EXE) for all occurences of EnableUlps, and set all values of that to zero (0). Please note that you need to restart Windows after disabling ULPS, and you need to do that procedure after every Catalyst upgrades. Quote
