Asus Rapmage IV Extreme (Chasis FAN Monitoring)
1) Do you have Asus AI Suite installed? If yes, then did you rename any of the fans in AI Suite?
2) Do you have the option Asus ATKEX sensor support enabled in AIDA64 / main menu / File / Preferences / Stability?
