fixed: Standby/sleep issues with Turing (Turzx) 8.8" LCD
Hello
I dont know if its the panel with its funky firmware or aida64, but after standby i have to reopen Aida to make the panel work again. Dont know how it was before, its the first time i bought and use Aida...
Edit: Its a newer version of the Turing/Turzx 8.8, because they always change firmwares...but i dont know where to read it out. Bought in September
  • Solution
9 hours ago, Checki said:
Hello
Let me know if it helps.
On 10/4/2025 at 11:36 PM, Checki said:
Seems to work now :)
But i wait another day to mark it as solution...
Thank you for your feedback!  I'm glad it works now :)
  • Fiery changed the title to fixed: Standby/sleep issues with Turing (Turzx) 8.8" LCD
