bukshta Posted December 22, 2025 Posted December 22, 2025 I have got new motherboard ASRock B850I Lightning WiFi and faced whith wrong CPU and Case fans RPM sensors displayed information. Now I have next structure and how it has to be: CPU    ---> has to be CPU2 (the first case fan connected into AIO Pump Fan Connector) Chassis #1   ---> has to be CPU (CPU fan connected into CPU Fan Connector) Chassis #2   ---> has to be Chassis (the second case fan connected into Chassis Fan Connector) In other monitor softwear all fans sensors are displayed correctly. I hope for your help. yhank you in advance.  isasensordump.txt Quote
Fiery Posted December 23, 2025 Posted December 23, 2025 On 12/22/2025 at 5:58 PM, bukshta said: I have got new motherboard ASRock B850I Lightning WiFi and faced whith wrong CPU and Case fans RPM sensors displayed information. Now I have next structure and how it has to be: CPU    ---> has to be CPU2 (the first case fan connected into AIO Pump Fan Connector) Chassis #1   ---> has to be CPU (CPU fan connected into CPU Fan Connector) Chassis #2   ---> has to be Chassis (the second case fan connected into Chassis Fan Connector) In other monitor softwear all fans sensors are displayed correctly. I hope for your help. yhank you in advance. Thank you, the issue will be fixed in the next AIDA64 beta update. Quote
Solution Fiery Posted January 18 Solution Posted January 18 On 12/22/2025 at 5:58 PM, bukshta said: I have got new motherboard ASRock B850I Lightning WiFi and faced whith wrong CPU and Case fans RPM sensors displayed information. Now I have next structure and how it has to be: CPU    ---> has to be CPU2 (the first case fan connected into AIO Pump Fan Connector) Chassis #1   ---> has to be CPU (CPU fan connected into CPU Fan Connector) Chassis #2   ---> has to be Chassis (the second case fan connected into Chassis Fan Connector) In other monitor softwear all fans sensors are displayed correctly. I hope for your help. yhank you in advance.  isasensordump.txt 75.93 kB · 2 downloads The above mentioned new AIDA64 beta update is now available for download: https://www.aida64.com/downloads/latesta64xebeta Quote
bukshta Posted January 22 Author Posted January 22 On 1/18/2026 at 6:44 PM, Fiery said: The above mentioned new AIDA64 beta update is now available for download: https://www.aida64.com/downloads/latesta64xebeta Thank you very much. But may be it would be better to rename AIO Pump to CPU2 as in structure I mentioned above (as in similar software)? If not tnan better to place AIO Pump on the second place after CPU and Chassis will be on the third place. Quote
bukshta Posted February 27 Author Posted February 27 On 1/22/2026 at 6:58 PM, bukshta said: Thank you very much. But may be it would be better to rename AIO Pump to CPU2 as in structure I mentioned above (as in similar software)? If not tnan better to place AIO Pump on the second place after CPU and Chassis will be on the third place. Hello. Any feedback? Quote
Fiery Posted February 27 Posted February 27 1 minute ago, bukshta said: Hello. Any feedback? We follow the labelling convention of ASRock, the manufacturer of your motherboard. Quote
bukshta Posted February 28 Author Posted February 28 On 2/27/2026 at 4:41 PM, Fiery said: We follow the labelling convention of ASRock, the manufacturer of your motherboard. I see. Thanks. Quote
