🚀 Introducing SynQPanel - A New Panel-Based Visualization Tool for AIDA64 Users
17 hours ago, Loyd said:
"implements AIDA-style $LABEL macro resolution (e.g. $CPUMODEL, $GPU1MODEL)." just how does this work? could not get it working.  also the names of the imported files are some sort of date function taken from the file I guess.  any way we could rename the file box?
Loyd
Thank you for testing and sharing feedback!!
Currently, $LABEL values can’t be fetched directly via Shared Memory, as only sensor values are exposed. To ensure a smooth and reliable experience, I’ve implemented a safe workaround that fetches these values and converts each $LABEL into its corresponding readable text label.
I’ve personally tested this on my system using the following available labels, and they’re working as expected:
  • $CPUMODEL
  • $GPU1MODEL
  • $GPU2MODEL
  • $CHIPSET
  • $MOBOMODEL
  • $OSPRODUCT
  • $DXVER
  • $HOSTNAME
  • $DNSHOSTNAME
  • $LOCALIP
  • $USERNAME
Since system configurations can vary, if you’re using or have any additional labels, please feel free to share them-I’ll be more than happy to incorporate and test those as well 😊
Also, do let me know if you notice any issues with the above displays.
You’re absolutely right about the imported name showing as a date. That name actually comes from the .sp2 file stored inside the .spzip package. The .spzip file is essentially a container that includes all SensorPanel assets-such as images-along with the .sp2 file, which holds everything from layout and positioning to size and configuration details.
The filename is used so changes can be written back to the correct file when you hit Save. That said, I’ll explore whether we can display the spzip name instead, to make this clearer and more intuitive 💡
17 hours ago, BHSY said:
Hi GaHile, so far, I’ve run into one issue: the font style isn’t working. I tested with a common font, Arial, selected Bold, and Italic, but nothing changed. The same problem occurs with other fonts as well.😟
The right‑click actions and the close‑to‑tray feature are working perfectly. 👍 Regarding $LABEL, no issue when I import a new .spzip panel. However, my existing .sqx panel with no name label was not updated. I need to reimport the .spzip panel and re-add the videos. Is there any way to update it from SynQPanel?
One question: if I changed to a new CPU, will $LABEL automatically update with the new processor name? I assume it will, since SynQPanel shares memory with AIDA.
Thanks.
Thank you for testing and sharing feedback!! 😍
Regarding the font issue, could you please let me know exactly where you’re facing the problem? I wasn’t able to reproduce it on my end-fonts appear to be working fine here. That said, something might still be off, and I’m absolutely here to track it down and fix it for you 🙂
I’m really glad to hear that the right-click actions and the close-to-tray feature are working perfectly and exactly as you expected 🎉 Thank you so much for adding this feature - it’s genuinely useful and a great enhancement!
Your observation about $LABEL behavior is spot-on 👍
There are no issues with newly created panels; however, existing panels behave differently at the moment.
At present, $LABELS are converted into hard-coded text labels inside SynQPanel. This approach was intentionally chosen as a first step-to verify compatibility across different systems and ensure values are fetched correctly. If this makes sense!!
To answer your question honestly:
If you switch to a new CPU (or similar hardware change), the $LABEL won’t automatically update right now, since it has already been converted into a static text label. :(
But please don’t worry-I am here and I’ve got your back 😄
I will explore whether $LABELS can be stored as sensors instead, so they dynamically update whenever system hardware changes. That’s the ideal behavior, and I’ll definitely test and validate this for you to make sure it works seamlessly 💪
Let me know if there’s anything else you’d like me to check or improve-I’m always happy to help!
  • Like 3
@Loyd @BHSY
Hi Everyone!
I am excited to announce 🎤 that 🎉SynQPanel v1.0.2 is now available.🎉
This release focuses on stability fixes and improved gauge handling.
Fixed
- Font Bold/Italic not applying correctly
- Close to Tray and Diagnostics settings not persisting after restart
- UI showing internal .sp2 filename instead of the original .spzip name
Improved - Additions
- Gauge label, font family, size, bold and italic are now correctly imported from AIDA
- Gauge label settings can now be fully adjusted inside SynQPanel
📢 Recommended update for all users.
Thank you to the AIDA team and community for feedback and logs that helped refine this release. 🙏
The update is available on GitHub here:
https://github.com/sursingh-hub/SynQPanel/releases/tag/v1.0.2
Feedback and suggestions are always welcome.   🙏  Thank you again for the support!   🙏
Is this the only place for discussion on synqpanel? No Discord?
Currently using infopanel which looks extremely similar, How do I import my infopanel template into synqpanel?
Cheers
Cheers
Hey, thank you for checking out SynQPanel - really appreciate it! 🙏
At the moment, this forum is the primary place for discussion and support. There isn’t a Discord server yet. That said, feedback like yours helps shape what comes next, so a Discord is definitely something I’m considering once the user base grows a bit more and things stabilize.
At the moment, SynQPanel is intentionally focused only on AIDA64 users. The goal is to keep SynQPanel lean, trimmed, stable, and deeply integrated with AIDA. We did not aim big at this point :)
Because of that:
  • There is no direct other Panel template import
  • SynQPanel does not read other Panel / Libre / HWiNFO formats
  • The supported import path is AIDA sensorpanel files (.sp2 / .spzip / etc.) only
If your other Panel setup is based on an AIDA sensorpanel (which many are), you can import that AIDA panel into SynQPanel and continue working from there. Once imported, SynQPanel will map with your AIDA sensors using AIDA64 amazing Shared Memory concept, lets you adjust layout, gauges, labels, fonts, and other properties in a more flexible way.
Thank you again for the interest and for taking the time to ask. Feedback from experienced panel users is incredibly valuable and directly influences where SynQPanel goes next ❤️
🙏 (we need you as we are just starting this journey!!) 🙏
Cheers!
  • Like 3
Posted (edited)
A showcase of my latest Sensor Panel, using SynQPanel to import AIDA64’s SensorPanel file and enhance it with animated visuals, featuring a fan that spins in sync with real-time speed and a rotating arc GIF.😊
Edited by BHSY
Updated the video with blinking light
  • Like 4
  • Thanks 1
i have a small issue synQ panel doesn't find my cpu fan, aida64 show it (it's written n°8 because before it was plugged somewhere else, i wanted to update the sensor and it doesn't appear in Synq)
Because of that:
If your other Panel setup is based on an AIDA sensrpanel (which many are), you can import that AIDA panel into SynQPanel and continue working from there. Once imported, SynQPanel will map with your AIDA sensors using AIDA64 amazing Shared Memory concept, lets you adjust layout, gauges, labels, fonts, and other properties in a more flexible way.
Cheers!
I understand that SynQpanel uses Aida64 sensors.........
Your user interface is exactly the same as infopanel. Im sure the UI is not the only thing thats identical to Infopanel.
Allowing importing of layouts from every other sensorpanel software should be a priority to help people transition to SynQpanel from what ever they are currently using, especially when your 1 to 1 with Infopanel lol.
I will keep my eye on this forum post for updates but until there is a layout import from Infopanel theres no point switching. I do not have the hours on hand to sort it all out again. Good luck with your journey, looks good but then again so does infopanel hence why i used it and hence why yours looks identical.
Cheers
Cheers
That’s completely fair, and I genuinely appreciate you taking the time to explain your perspective.
You’re right - from a user’s point of view, rebuilding a complex layout from scratch is a real time investment, and not everyone has the hours (or patience) to do that again. I fully understand why, today, that makes sticking with InfoPanel the practical choice for you.
On the UI similarity: yes, SynQPanel will feel familiar -  and that’s intentional. The goal was zero learning friction for AIDA users, not to reinvent UI patterns just for the sake of looking different. Under the hood though, SynQPanel is being shaped around AIDA-only workflows, tighter control over gauges, labels, fonts, and long-term stability rather than broad multi-source support.
You’re also absolutely right that layout import from other panel systems would lower the barrier to entry. It’s a valid request, and it’s on my radar - but I also want to be transparent: SynQPanel currently has a very small user base, and development is focused first on getting the AIDA experience rock-solid before expanding migration tooling. Right now my aim is to stabilize this application and it has lots known issues which we will definitely resolve together. That kind of feature only really becomes viable once there’s enough momentum and feedback to justify the complexity.
If you decide to just keep an eye on things for now, that’s totally fine - I respect you, no pressure at all. But if at any point you do try SynQPanel, even casually, feedback from experienced users like you genuinely helps shape where it goes next. Early-stage projects live or die by that kind of input. I really mean it, it wasnt easy to build something like this and I hope you understand and trust me!
Thank you again for being honest, and for keeping the conversation constructive. Hopefully SynQPanel earns another look from you down the road.
Cheers 🍻
  • Like 3
Thank you for the screenshot - that helps a lot 👍
Since the sensor is clearly visible in AIDA64, the next important thing to check is whether it’s exposed to external applications via shared memory, as SynQPanel can only read sensors that AIDA explicitly publishes.
Could you please check the following in AIDA64:
  1. Go to Preferences → External Applications
  2. Open the Shared Memory section
  3. Make sure the CPU fan / flow sensor is enabled and checked there
  4. If possible, please share a screenshot of that Shared Memory list
A couple of additional things worth checking:
  • Start order matters
    Please make sure AIDA64 is fully running first, then start SynQPanel.
    SynQPanel reads the sensor map at startup, so if AIDA isn’t ready yet, some sensors may not be picked up.
  • Sensor name differences
    Sometimes fans or pumps still appear under their original header name (for example CPU_FAN, FAN #8, PUMP, or Flow) even if they were renamed later in AIDA.
    It’s worth checking if it shows up under a slightly different name in SynQPanel.
If it still doesn’t appear after checking the Shared Memory list, feel free to send me a PM and I’ll guide you on what logs or details are useful so we can diagnose this properly and improve detection for cases like this.
Thank you again for reporting it - feedback like this really helps improve SynQPanel 👍
thank you, you were right, the cpu fan wasn't checked
  • Thanks 1
I love your software. It did fail on me with the following error message:
Application: SynQPanel.exe
CoreCLR Version: 8.0.2325.60607
.NET Version: 8.0.23
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Thank you for reporting this, and I’m really glad to hear you’re enjoying SynQPanel ❤️
I’m sorry it failed on you - that kind of crash is frustrating, and I appreciate you taking the time to share the details.
The exception you’re seeing (System.AccessViolationException) usually means the app tried to access memory that was no longer valid. In SynQPanel’s case, this is almost always related to native interop, such as:
  • AIDA64 shared memory access
  • SkiaSharp / graphics rendering
  • Sensor data becoming unavailable or changing unexpectedly while being read
It’s not a .NET logic error and it’s not something caused by normal usage.
To help narrow this down, could you please let me know (or send via PM if you prefer):
  1. What was happening just before the crash?
    (e.g. opening a profile, switching panels, resizing, minimizing to tray, closing the app, etc.) Without that change: Is the app working properly?
  2. Was AIDA64 running at the time, and if so:
    • Version of AIDA64
    • Whether shared memory was enabled
  3. When exactly error occurred (Installing, launching etc.)?
  4. If possible, please check this folder after the crash and let me know if a latest log exists:
%LOCALAPPDATA%\SynQPanel\
i.e.
C:\Users\<USERNAME>\AppData\Local\SynQPanel\logs
Latest Log Files can be very helpful.
I’m actively improving stability around shared memory access and rendering, and reports like this are extremely valuable - especially this early, while the user base is still small.
Thanks again for your support and patience. I’ll do my best to get this fully understood and addressed.
The error occurred while the computer was idling; it happened twice. First at 4:31 am and a second time at 7:39 pm the same day (first log file will not upload, exceeds upload limit)
  • Version of AIDA64, 8.20.8110 Beta
  • Whether shared memory was enabled, yes
SynQPanel-20260119_018.log
  • Thanks 1
Thank you for the detailed follow-up - this is extremely helpful 👍
Based on the logs you shared, I can now say with confidence what’s happening. I have sent you a direct message to keep you informed with more details!
What I’m doing next
I’m already working on improvements to make SynQPanel more defensive in this exact situation, including:
  • Stronger validation before XML parsing
  • Safer early-abort paths when corruption is detected
  • Ensuring malformed shared-memory reads can never reach rendering code
This will be part of an upcoming update.
Thank you again for taking the time to report this and share logs.
This kind of feedback is invaluable, especially while SynQPanel is still growing. 🙏
  • Like 2
On 1/25/2026 at 7:01 AM, AveMe said:
Hi,
Will this work in the future with WigiDash by any chance?
Thank you for reaching out!
Currently, our focus is to work with AIDA's shared memory only and make application stable.
If there is any API or Plugin support for WigiDash: we are open to test and experiment that!!
P.S. Hardware, USB, Screens etc. are supported inside AIDA only.
Hey guys!
I poured my heart and soul into building this-late nights, nonstop effort, and a whole lot of belief. I didn’t disappear… I was just deep in the grind 😄
No GIFs. No animations. No extra fluff. No knowledge is required!!
Just drop in your numbers as simple, static images (PNGs), and let SynQPanel work its magic.
This is still a work in progress, still being tested-but what’s coming is something I’m genuinely proud of, and I can’t wait for you to experience it.
Special Thanks and shout out to @BHSY and @Surjeet for giving this idea and helping me on this:
  • Like 4
Cheers 🍻
I am the original developer of InfoPanel (IP). Have been receiving multiple PMs regarding this. Anyway, IP is open source and GPL. Anyone is welcome to modify. I’ve checked the repo of SynQPanel, it’s clearly adapted from IP based on the structure, classes etc. I know because I wrote most if not all of it by hand, before Claude and such.
It’s actually an honour that someone wants to take my work and adapt it. Attribution could be better. But users who know will know and it doesn’t bother me much. It would be better if you responded directly to such queries so that I stop receiving PMs of “someone is stealing/ripping IP”.
Lastly, I was approached by @Surjeet regarding this before launch. I did not object. I also gave advice. Therefore I am not surprised by this. The main ask I had was that in the spirit of open source, if you have a singular feature to add I hope that you add it to the original code base so that more users can benefit from it. If you have a fix for the original software it would be great to also contribute to the original code base.
I understand where this project is heading. However inevitably, you are going to be asked to support IP formats, or directly support LCDs and the like. If you accede and become more like IP, it would contravene the above mentioned spirit.
  • Thanks 1
8 hours ago, GaHile said:
Hey guys!
The 1st half of the flip looks fantastic, and the execution is super clean! 🩷
  • Thanks 1
Thank you for addressing this publicly - I genuinely appreciate you stepping in and responding to the speculation directly.
You’re absolutely right: SynQPanel started as an adaptation of InfoPanel, which is GPL and open-source. I also want to acknowledge and thank you again for the insight and advice you shared before launch. Your openness, guidance, and lack of objection at the time were appreciated then and still are now.
From the beginning, SynQPanel was never intended to replace InfoPanel or compete with it feature-for-feature. The goal has always been much narrower: to focus specifically on the AIDA64 user base, remove broader hardware stacks (HWiNFO, Libre, LCD support, etc.), and explore a more tightly scoped, AIDA-centric workflow. That focus is a deliberate design choice-not an attempt to re-create InfoPanel under a different name.
I also agree with you on attribution. I’ll make this clearer in the project documentation so users understand the lineage and speculation can be put to rest. Transparency benefits everyone.
On contributing back: where fixes or improvements are generic and useful to InfoPanel’s broader audience, I agree that upstreaming them makes sense and aligns with the spirit of open source.
And for clarity to AIDA lovable users following this thread: SynQPanel is intentionally not designed to support InfoPanel formats, LCD, USB hardware, or act as a drop-in replacement. The scope is narrower by design, and that’s intentional. THIS WILL REMAIN Forever!!
Thank you again for engaging constructively - and for the work you’ve done on InfoPanel over the years. A lot of people here, myself included, have benefited from it.
Thank you @BHSY, I am glad you liked the results.
12 hours ago, Loyd said:
Looks good cannot wait!!!
Thank you @Loyd for your encouragement!!
This is still WIP and will launch in the next update after good testing :) Thank you!
  • Like 2
@BHSY @Loyd
Hi Everyone!
I am excited to announce 🎤 that 🎉SynQPanel v1.0.3 is now available.🎉
 ❤️ So many New Things ❤️
Runtime Data Storage & Stability
  • Added configurable runtime data folders for assets, logs, and cache, while keeping profiles and settings in AppData for safer upgrades and backups
  • Improved XML parsing robustness to better handle malformed or partial files without crashing
  • Hardened shared-memory handling to reduce the risk of corruption-related crashes and improve long‑running stability
Added New add-ons:
TimePulse:
  • Introduced the TimePulse add-on to drive time-based triggers and visual pulses for panels
  • Enables creating more dynamic, rhythm-based visual elements that react to seconds, minutes, or custom time intervals
Weather:
  • Added a Weather add-on powered by WeatherAPI.com, exposing current conditions, detailed daily forecasts, air quality, and astronomy data
  • Added multiple icon URL sensors (current, today, tomorrow, hourly) to build rich weather widgets with live condition icons on the sensorpanel
Added Flip Clock:
  • Implemented a standalone Flip Clock mode that runs independently and renders smooth flipping digit animations without relying on external data sources
  • Provides smooth flipping digit animations suitable for use as a primary time widget or background clock
Improvements and fixes:
  • Improved HTTP image caching so plugin-provided icon URLs stay in memory reliably without premature eviction or disposed-image errors
  • Refined plugin sensor UI so the \"Add Http image\" action is only enabled for URL-based sensors, including the new weather icon sensors
  • Fixed CPU fan selection issue that was switching to a different sensor source
  • General minor stability and UX improvements across plugins and the rendering pipeline
Thank you to the AIDA team and community for feedback, suggestions and logs that helped refine this release. 🙏
https://github.com/sursingh-hub/SynQPanel/releases/tag/v1.0.3
I am not a designer but I tried something below> Please use the steps and let me know if you have any questions:
Flip Clock: Please use images named from 00 to 59.png only
Weather Settings:
Adding amazing looking icons for weather/time conditions etc. that will change automatically:
  • Like 3
Thank you @GaHile for such an amazing update 🎉👏
Made with SynQPanel v1.0.3: Just a random Try :) for weather and flip effects!! 😇
I think Flip will become more attractive/powerful in the future. Start is good. Kudos!! 🫡
  • Like 2
  • Thanks 1
Thanks for testing it out!
Flip will continue to evolve over time. It may look effortless, but getting here took real work (you know that :)) -and this is only the beginning.
  • Thanks 2
