Soul--Reaver Posted January 4 Posted January 4 System: AMD 5700G, Asus B550-F, Adaptec ASR 8805 raid card, 8 * HGST HUH728080ALE600 Problem: Aida64 7.70.7500 was able to retrieve, among other things, the RAID and Smart information of the Adaptec ASR 8805. The necessary stability checkmarks are turned on but Aida64 8.00.8000 and later versions do not show the Smart data of the disks connected to the Adaptec ASR 8805. See the screenshots of the 2 Aida64 versions running the same aida64.ini file and the missing information. raiddump_aida64 8.00.txt raiddump_aida64 7.70.txt smartdump_aida64 8.00.txt smartdump_aida64 7.70.txt Quote
dejiko Posted January 5 Posted January 5 Same problem, just update version from 6.9 to 8.2, raid card works well with old version, but new version doesn't work. Already enabled Adaptec Raid support in preferences. Quote
Fiery Posted Thursday at 04:38 PM Posted Thursday at 04:38 PM On 1/4/2026 at 2:33 AM, Soul--Reaver said: System: AMD 5700G, Asus B550-F, Adaptec ASR 8805 raid card, 8 * HGST HUH728080ALE600 Problem: Aida64 7.70.7500 was able to retrieve, among other things, the RAID and Smart information of the Adaptec ASR 8805. The necessary stability checkmarks are turned on but Aida64 8.00.8000 and later versions do not show the Smart data of the disks connected to the Adaptec ASR 8805. See the screenshots of the 2 Aida64 versions running the same aida64.ini file and the missing information. @dejiko Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
