Fiery Posted 14 hours ago Posted 14 hours ago On 4/5/2026 at 4:21 PM, Psychorama said: It works, BUT, the same as with HWInfo, there are USB disconnects when multiple sources try to get information from the WireView 2. Also, when you have "fast startup" enabled on Windows 11, the connection is not possible anymore, until you reboot, or turn off fast startup. I know HWInfo fixed this issue, but i'm not sure how. When every monitoring accessing this information is turned off, it will most likely work. @fip00 can you try to turn off fast startup, turn off auto-start off the wireview software, and possibly HWInfo? My biggest guess is it will start working again. @Fiery can you look into this? We're looking into it, thank you! Quote
