HoboWithAShotgun Posted April 20 Posted April 20 my main monitor is at 175% scale and my 800x480 raspbery pie is 100% when i drag the window from main monitor onto the raspberry pi its way to big and often just forces IT back to main monitor. and yes i TRIed teh high dpi shit and cahnge to "system" it displays properly msot of time on main monitor but have that issue. ive clicked the "pinned to monitor" to pin it to the raspberry pie but doesnt display at all on it when i do that clicked reset position and nothing. dunno what to do. Quote
Fiery Posted April 20 Posted April 20 9 hours ago, HoboWithAShotgun said: my main monitor is at 175% scale and my 800x480 raspbery pie is 100% when i drag the window from main monitor onto the raspberry pi its way to big and often just forces IT back to main monitor. and yes i TRIed teh high dpi shit and cahnge to "system" it displays properly msot of time on main monitor but have that issue. ive clicked the "pinned to monitor" to pin it to the raspberry pie but doesnt display at all on it when i do that clicked reset position and nothing. dunno what to do. Make sure to use the latest AIDA64 beta build available at: https://www.aida64.com/downloads/latesta64xebeta Start with adjusting your SensorPanel on your main monitor. Set the SensorPanel resolution to 1400x840 in AIDA64 / Preferences / Hardware Monitoring / SensorPanel, and then pin it to your secondary screen on the same page of the AIDA64 Preferences. Once the SensorPanel properly occupies and fills your secondary monitor, you can keep on designing the layout the way you want. Quote
