Johnmcf2 Posted August 22 Posted August 22 When I switch to Fahrenheit the gauges use Celsius warning levels. normal Celsius levels show maximum high temp when changing to Fahrenheit readings. Quote
Fiery Posted August 29 Posted August 29 On 8/22/2026 at 7:58 PM, Johnmcf2 said: When I switch to Fahrenheit the gauges use Celsius warning levels. normal Celsius levels show maximum high temp when changing to Fahrenheit readings. Gauge limits are indeed not adjusted or modified when you switch between Celsius and Fahrenheit. Due to rounding we deem this is better than coming up with odd values for maximums after switching between Celsius and Fahrenheit. Quote
