ROG Crosshair 2006 โ€“ incorrect/missing motherboard sensor readings in AIDA64
ROG Crosshair 2006 โ€“ missing/incorrect motherboard sensor readings in AIDA64
Hi,
Iโ€™m experiencing a sensor monitoring issue in AIDA64 on an ASUS ROG Crosshair 2006 (X870E).
In the latest AIDA64 version, some motherboard sensors either disappear completely or show incorrect values.
In the previous version, the sensors would disappear intermittently: sometimes they were detected correctly after launching AIDA64, and sometimes they were missing.
The issue seems related to ASUS monitoring software. After installing Armoury Crate or ASUS MB Manager, motherboard sensor readings in AIDA64 become unreliable or disappear.
At the same time, HWiNFO reads the same motherboard sensors correctly and consistently, even when AIDA64 has the issue.
System:
  • ASUS ROG Crosshair 2006 (X870E)
  • Windows 11, latest build
  • AIDA64: latest version
  • Armoury Crate / ASUS MB Manager installed
  • HWiNFO: no sensor issues
Could you please check whether there is a compatibility issue with sensor monitoring on the ROG Crosshair 2006, especially when ASUS monitoring services are installed?
I can provide sensor dumps, ISA Sensor Debug information, or other diagnostics if needed.
Hi,
System:
If the issue persists, please post an ISA Sensor Dump and we'll investigate it further.
I installed the latest AIDA64 beta and rebooted Windows, but the issue remains.
Iโ€™m attaching the ISA Sensor Dump.
isasensordump_x870crosshair2006.txt
  • Solution
isasensordump_x870crosshair2006.txt 8.54 kBย ยทย 2 downloads
Thank you!ย  Please upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know if it helps.
  • Thanks 1
