P.J Posted August 28 Posted August 28 Hello AIDA64 doesn't show the CPU/MB temperatures of ECS B75H2-M3 (V1.0) and the voltages are wrong too 🤔 Quote
Fiery Posted August 29 Posted August 29 13 hours ago, P.J said: Hello AIDA64 doesn't show the CPU/MB temperatures of ECS B75H2-M3 (V1.0) and the voltages are wrong too 🤔 In AIDA64 please press Ctrl+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery 1 Quote
P.J Posted August 29 Author Posted August 29 1 hour ago, Fiery said: In AIDA64 please press Ctrl+D --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Here you are: isasensordump.txt Quote
Fiery Posted August 29 Posted August 29 1 hour ago, P.J said: Here you are: isasensordump.txt 8.38 kB · 1 download Thank you! It's a bit difficult to figure out the register layout, and it'd help tremendously if you could post a screenshot of the H/W Monitor (a.k.a. PC Health Status) page of the BIOS Setup where it shows all the thermal and voltage readings for your motherboard. 1 Quote
P.J Posted August 29 Author Posted August 29 4 hours ago, Fiery said: Thank you! It's a bit difficult to figure out the register layout, and it'd help tremendously if you could post a screenshot of the H/W Monitor (a.k.a. PC Health Status) page of the BIOS Setup where it shows all the thermal and voltage readings for your motherboard. I could only find these: Quote
Fiery Posted September 19 Posted September 19 On 8/29/2026 at 6:45 PM, P.J said: I could only find these: Thank you! We've implemented sensor adjustments in the latest AIDA64 update of v8.40 available at: https://www.aida64.com/downloads/latesta64xe Quote
