Chaoscraig Posted September 11 Posted September 11 Hey all, I have an LCD display sensor panel on my ASUS Reujin III extreme. Wondering if there is a way to make temp sensor indicators link to a particular SATA port number of a corresponding drive. I have hot swap bays and wanted the sensor panel layout to spatially correspond to the location each bay. The Issue is when drives are added and removed the drive list reindexes and then my sensors get messed up. Quote
Fiery Posted September 11 Posted September 11 4 hours ago, Chaoscraig said: Hey all, I have an LCD display sensor panel on my ASUS Reujin III extreme. Wondering if there is a way to make temp sensor indicators link to a particular SATA port number of a corresponding drive. I have hot swap bays and wanted the sensor panel layout to specially correspond to the location each bay. The Issue is when drives are added and removed the drive list reindexes and then my sensors get messed up. I'm afraid there's no perfect solution in AIDA64 to handle such special scenarios that you've described 😞 Quote
Chaoscraig Posted September 11 Author Posted September 11 no perfect solution or not any solution ? Quote
Fiery Posted September 14 Posted September 14 On 9/11/2026 at 4:13 PM, Chaoscraig said: no perfect solution or not any solution ? What I meant to say is that you cannot link the sensor items to any specific SATA ports or M.2 slots. Hot-swap is supported in a way that when you remove a drive and install a new one, it will re-use the previous sensor item of the removed drive so by removing e.g. 50% of the drives you've got in your system and replacing them with other ones, the SensorPanel layout will still continue monitoring the new drives, the layout won't get half empty so to speak. Quote
Chaoscraig Posted September 15 Author Posted September 15 Has any one considered writing a code that refreshes the sensor items upon any hardware rescan (something that windows does when adding or removing a drive). I'm guessing it cant do it by SATA port but i can see how it would be possible to do by drive name/desc. This subroutine could try and match temp sensor items with the drives of matching names. Because its clear AIDA64 already has a way of retrieving those names when it populates the sensor items initially. Quote
