MAA Posted September 18 Posted September 18 Hello, When the switch to version 8 was made, I expected updated benchmarks; however, that didn't happen, and CheckMate remains the only new benchmark to date. I had already suggested updating certain benchmarks, but I’ve now consolidated those ideas into a single post. CPU: CheckMate - OK PhotoWorxx - should be replaced, for example, with the VVC/EVC/AV2 encoding benchmark Zlib - must be replaced with a faster implementation, for example Zlib-ng https://github.com/zlib-ng/zlib-ng AES - OK +However, it is also necessary to add the ChaCha20 (used in TLS 1.3) benchmark, which is relevant for processors without AESNI https://en.wikipedia.org/wiki/ChaCha20-Poly1305 +In addition, it is desirable to add the new AEGIS benchmark (proposed for future use with TLS) https://cfrg.github.io/draft-irtf-cfrg-aegis-aead/draft-irtf-cfrg-aegis-aead.html SHA3 - OK +However, it is also necessary to add a SHA-2 benchmark capable of utilizing SHA instructions https://en.wikipedia.org/wiki/SHA_instruction_set FPU: Julia - OK Mandel - must be refined for better multithreading support https://forums.aida64.com/topic/13433-threadripper-7975wx-bench-results/#comment-63473 SinJulia - OK FP32 RayTrace - OK FP64 RayTrace - OK +It would also be interesting to see the LINPACK benchmark (or at least DGEMM/SGEMM) NPU: some benchmark needs to be added Quote
MAA Posted September 27 Author Posted September 27 I also discovered some strange SHA3 results. Why doesn't the Zen 5 architecture gain an advantage over Zen 4? Why doesn't the 512-bit datapath gain an advantage over the 256-bit datapath? Perhaps additional AVX-512 optimizations are required? Quote
MAA Posted October 2 Author Posted October 2 If SHA3 can't be optimized, I suggest adding BLAKE3, which supports practically unlimited degree of parallelism (both SIMD and multithreading) https://shattered.io/blake3-vs-sha-3-2026/ Quote
