Hello @Fiery,
I’ve run into a problem with the GPU Hotspot sensor. Yesterday I noticed it reports the same temperature as GPU Temp. I set it up as a simple sensor item and a custom gauge, but after saving and re‑importing, it always reverts to GPU Temp. I also tried setting it up as a sensor item; the result was the same.
For reference, I’m currently using AIDA64 version 8.40.8510 Beta with an Asus TUF RTX 5070 Ti Gaming 16GB running the latest NVIDIA driver 617.42. The same result occurs on version 8.40.8505 Beta as well. Please refer to the attached screenshots.
Best regards,
Bryan (BHSY)
