mrfreeman552 Posted May 1, 2014 Posted May 1, 2014 Hi all, I have this problem where for some reason AIDA doesn't show anything on the System Uptime page under Operating System section. It's just blank with no text whatsoever, though all other pages seem to work fine. I also have Everest installed and have the same problem there, tried re-installing it without success, now the same thing is happening in AIDA. I recently did a clean install of my OS (Windows 7 Ultimate 32-bit SP1), and never had that problem in Everest prior to that. I had the same system, installed from the same disc. Any ideas on how to fix this? Any help will be very appreciated. Quote
Fiery Posted May 2, 2014 Posted May 2, 2014 1) Does your Windows user have the necessary permissions to access the Event Logs facility? 2) Have you tried it with the latest AIDA64 Extreme beta release available at: http://www.aida64.com/downloads/aida64extremebuild2932t6rgsj2cxhzip Regards, Fiery Quote
mrfreeman552 Posted May 2, 2014 Author Posted May 2, 2014 Thank you for your reply. I did some more research in the meantime and did find out that my event log is in fact not working, apparently it somehow got turned off when I cleaned the registry using CCleaner. I'm still trying to find a way to get it to run again, so once that is done, I will let you know whether that solves the problem. Update: I fixed the Event Log and that solved the problem. Thanks again! Quote
