Hello. Aida64 can not read sensors. Window does not close, when you try to kill the process, say "unable to terminate aida64.exe" . Helps only restart PC. Tried on last stable and beta versions. Help, please. Sorry for my bad english.
Does your Windows user have administrator privileges?  If yes, then please make sure to properly install AIDA64.  It is not advised to simply launch AIDA64.EXE from the ZIP package, without extracting all files.
No, I don't think you've done it right, since there are no icons there ;)  Please downoad the latest beta ZIP package, and extract all files into an empty folder, and run AIDA64.EXE from that folder.
I thought that you need to extract a single file, extract all the files here. Summary information, are not all loaded
after a while, the whole window freezes, process loads one core and can not close it
Read the next topic of reset bios, decided to try, aida start. The problem was setting ASUS/3rd Party UI Priority was in the value of 3rd Party Utility, I changed it to ASUS Utility. Strange of course, but good, that I understood why. Thanks Fiery. Sorry for my english
