Hi,
I have a customer with stability issues, his specs are as follows-
i74930k @ 4.6GHz
16GB 2133MHz RAM
EVGA GTX 780 Ti Classified
H100i
When the CPU, FPU, cache and memory tests are run at the same time the system passes overnight with no issues.
When the GPU only test is run the system passes also.
When the five tests are run together the system fails after a few hours.
Moderators, do you have any ideas?
Aaron
I suppose the system is simply not stable when all components are under heavy stress.  It would worth trying to update the BIOS to the latest one, and return settings to factory defaults (no overclocking).  In case the system passes an overnight stress test that way, then the issue was due to an excessive overclocking.
My thoughts exactly.
Thanks for the help.
