ACHU Posted August 20, 2014 Posted August 20, 2014 Hi, Recently we used AIDA64 to monitor the CPU temperature as well as throttling activation, but noticed something weird. When we stressed some systems using other s/w for 12 hours and AIDA64 was used for monitoring only. The test data showed that the CPU temp went up to 88~93C during the 12 hrs and AIDA64 showed no CPU throttling ever occured. After 12 hrs, the s/w that used to stress the system stopped, but AIDA64 kept monitoring the system. We found the CPU temperature going up and some units even had CPU throttled. Then we did another test. We still used AIDA64 to monitor the CPU temperature and throttling but didn't use any s/w to stress the system. However, CPU temperature still went up and throttled after a few hours. When AIDA64 is used for monitoring only, does it still stresses the system? Is there any setting we need to change to make sure that AIDA64 is simply monitoring but not giving loading? Quote
Fiery Posted August 20, 2014 Posted August 20, 2014 AIDA64 will not stress or load the system when you only use it for monitoring purposes. I'm afraid you haven't provided enough details on the issue to discuss it further. For example, it would be important to know what kind of computers are they, and whether you could see any actual CPU load (via e.g. Task Manager) when your processors were throttling while you were using AIDA64. And if you saw any actual CPU load, it would be important to know whether they were caused by the AIDA64 main process (aida64.exe) or some other process or service. Regards, Fiery Quote
