1) Open AIDA64 on your main rig, go to main menu / File / Preferences / Hardware Monitoring / LCD, click on the RemoteSensor tab, change the port to 8080, check enable.
2) Windows and/or your firewall software may pop up a message box warning you about a software (AIDA64) opening the 8080 port. Just allow it ;)
3) On the Android device open Chrome or your preferred web browser, and enter your main rig's IP address (which you can find on the Computer / Summary page in AIDA64, look for Primary IP Address there) and :8080 as the URL, like this:
http://192.168.0.1:8080
4) A splash screen should appear in your web browser informing you about the resolution you're supposed to use.
5) Go back to AIDA64 / main menu / File / Preferences / Hardware Monitoring / LCD, uncheck the enable option, and enter the resolution the splash screen stated. Then check enable again.
6) Go back to AIDA64 / main menu / File / Preferences / Hardware Monitoring / LCD / LCD Items, and you can start building your own LCD layout.
Would this be the same with a router in between?
If you configure port forwarding, then you could use it outside from your LAN, via the internet.
