mn12 Posted March 22, 2011 Posted March 22, 2011 Hi, on my MB the fan speed readings stops when the rpm is lower than 380 this behavior is the same in all programs so this is a MB issue. I use PWM to control my CPU-fan that can go below 400 (Scythe) and when it does AIDA64 takes the readings from the chassis fan and displays it as the CPU fan speed. The first screenshot is AIDA, HWINFO32 and Speedfan and all 3 displays the 3 fan speeds correct (the polling interval is slightly off). The second screenshot shows that when the RPM of the CPU fan drops below 380 and the MB reports RPM 0 AIDO takes FAN1 and displays it as the CPU fan. In both pictures the chassis fan speed (FAN1) is constant at 430RPM. Hardware: MB: MSI P6N Platinum CPU: Q6600 Fans: Scythe, Arctic Cooling and Silverstone EDIT: I forgot the AIDA64 version: 1.20.1150 Regards Simon Quote
Fiery Posted March 23, 2011 Posted March 23, 2011 1) Please copy-paste the full content of the Computer / Sensor page of AIDA64 into this topic. 2) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. 3) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic. Thanks, Fiery Quote
mn12 Posted March 23, 2011 Author Posted March 23, 2011 Hi, in this c ase the CPU fan speed is displaying the chassi fan Field Value Sensor Properties Sensor Type Fintek F71882/883 (ISA A00h) GPU Sensor Type Diode (ATI-Diode) Motherboard Name MSI MS-7350 Temperatures CPU 31 °C (88 °F) CPU #1 / Core #1 33 °C (91 °F) CPU #1 / Core #2 32 °C (90 °F) CPU #1 / Core #3 28 °C (82 °F) CPU #1 / Core #4 29 °C (84 °F) Aux 39 °C (102 °F) GPU Diode (DispIO) 42 °C (108 °F) GPU Diode (MemIO) 39 °C (102 °F) GPU Diode (Shader) 46 °C (115 °F) SAMSUNG HD103SI 19 °C (66 °F) Cooling Fans CPU 438 RPM GPU 35% Voltage Values CPU Core 1.144 V +3.3 V 3.376 V +5 V 4.965 V +12 V 12.408 V +3.3 V Standby 3.376 V VBAT Battery 3.072 V Chipset 1.328 V DIMM 1.760 V ISA ------[ AIDA64 v1.20.1150 ]------ ------[ Microsoft Windows Vista Ultimate 6.0.6002 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-071207-Crush55$1ADKV000_A7350NMS V1.4 071207 Motherboard Model : MSI P6N SLI Platinum (MS-7350) Motherboard Chipset : nVIDIA nForce 650i SLI DMI MB Manufacturer : MSI DMI MB Product : MS-7350 DMI MB Version : 1.0 DMI MB Serial : To be filled by O.E.M. DMI SYS Manufacturer: MSI DMI SYS Product : MS-7350 DMI SYS Version : 1.0 DMI SYS Serial : To Be Filled By O.E.M. DMI BIOS Version : V1.4 ITE 87xx Port = 00h ITE 87xx HWMonitor Port = 0000h ITE 87xx Device ID = 0000h ITE 87xx Version = 00h Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port = 0000h Winbond SuperIO Device ID = 0541h Fintek SuperIO Port = 4Eh Fintek SuperIO HWMonitor Port = 0A00h Fintek SuperIO Device ID = 0541h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = FFFFh ------[ LM78 ISA Sensor Device at 0A00 ]------ 0000 FF 03 00 00 FF FF FF FF FF FF 00 00 55 4C 00 00 0010 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF 0020 D3 97 6F 53 76 8D 73 D2 C0 FF FF FF FF FF FF FF 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0050 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF 0060 00 00 00 00 FF FF 02 78 00 00 FF 0E 40 24 FF 08 0070 FF FF 20 FF 26 FF 80 FF FF FF FF FF FF FF FF FF 0080 FF FF 4B 4B 64 55 55 46 FF FF FF FF FF FF A8 FF 0090 00 0F 0C 00 02 FF 7D FF 42 24 FF AA 55 55 FF 0A 00A0 0F FF 00 20 02 1B 34 30 2C 28 FF C5 8E 57 20 0D 00B0 0D 5F 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0E 00C0 0F FF 00 FF 02 7B 3C 32 28 1E FF D9 B2 99 80 0F 00D0 0F FF 00 80 03 FF 3C 32 28 1E FF D9 B2 99 80 0F 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 00 00 00 00 00 00 3D FF 03 6C FF 00 FF FF FF FF Bnk0 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF Bnk1 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF Bnk2 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF Bnk3 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF Bnk4 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF Bnk5 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF Bnk6 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF Reg$20 CPU Core: r = 211, r*0.016 = 3.38 Reg$21 CPU Aux: r = 151, r*0.016 = 2.42 Reg$22 +3.3 V: r = 111, r*0.016 = 1.78 Reg$23 +5 V: r = 83, r*0.016 = 1.33 Reg$24 +12 V: r = 118, r*0.016 = 1.89 Reg$25 -12 V: r = 141, r*0.016 = 2.26 Reg$26 -5 V: r = 115, r*0.016 = 1.84 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : Full ------[ AIDA64 v1.20.1150 ]------ ------[ Microsoft Windows Vista Ultimate 6.0.6002 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-071207-Crush55$1ADKV000_A7350NMS V1.4 071207 Motherboard Model : MSI P6N SLI Platinum (MS-7350) Motherboard Chipset : nVIDIA nForce 650i SLI DMI MB Manufacturer : MSI DMI MB Product : MS-7350 DMI MB Version : 1.0 DMI MB Serial : To be filled by O.E.M. DMI SYS Manufacturer: MSI DMI SYS Product : MS-7350 DMI SYS Version : 1.0 DMI SYS Serial : To Be Filled By O.E.M. DMI BIOS Version : V1.4 ------[ GPIO @ isa 44C0 ]------ 0000 48 48 60 65 48 44 48 48 48 48 44 44 44 44 60 60 0010 60 68 68 68 68 48 48 48 48 48 48 48 48 48 48 48 0020 48 48 28 28 48 68 68 68 68 48 68 48 48 68 48 00 0030 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 ------[ 2 SMBuses detected ]------ ------[ SMBus #0 ]------ SMBus Type : nForce2/3/4/5/6 - Primary SMBus Port : 5000 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B00-D50 ]------ 0000 80 08 08 0E 0A 61 40 00 05 30 45 00 82 08 00 00 .....a@..0E..... 0010 0C 04 38 01 02 00 03 3D 50 50 60 3C 1E 3C 2D 80 ..8....=PP`<.<-. 0020 20 27 10 17 3C 1E 1E 00 00 3C 69 80 18 22 00 00 '..<....<i..".. 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 72 ...............r 0040 7F 98 00 00 00 00 00 00 05 39 39 30 35 33 31 36 ........9905316 0050 2D 30 30 35 2E 41 30 34 4C 46 00 00 00 07 27 17 -005.A04LF....'. 0060 30 98 79 00 00 00 00 00 00 00 00 00 00 00 00 00 0.y............. 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 39 39 30 35 33 31 36 2D 30 30 35 2E 41 30 34 4C 9905316-005.A04L ------[ SMBus Device B00-D51 ]------ 0000 80 08 08 0E 0A 61 40 00 05 30 45 00 82 08 00 00 .....a@..0E..... 0010 0C 04 38 01 02 00 03 3D 50 50 60 3C 1E 3C 2D 80 ..8....=PP`<.<-. 0020 20 27 10 17 3C 1E 1E 00 00 3C 69 80 18 22 00 00 '..<....<i..".. 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 72 ...............r 0040 7F 98 00 00 00 00 00 00 05 39 39 30 35 33 31 36 ........9905316 0050 2D 30 30 35 2E 41 30 34 4C 46 00 00 00 07 27 18 -005.A04LF....'. 0060 30 99 79 00 00 00 00 00 00 00 00 00 00 00 00 00 0.y............. 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 39 39 30 35 33 31 36 2D 30 30 35 2E 41 30 34 4C 9905316-005.A04L ------[ SMBus Device B00-D52 ]------ 0000 80 08 08 0E 0A 61 40 00 05 30 45 00 82 08 00 00 .....a@..0E..... 0010 0C 04 38 01 02 00 03 3D 50 50 60 3C 1E 3C 2D 80 ..8....=PP`<.<-. 0020 20 27 10 17 3C 1E 1E 00 00 3C 69 80 18 22 00 00 '..<....<i..".. 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 72 ...............r 0040 7F 98 00 00 00 00 00 00 05 39 39 30 35 33 31 36 ........9905316 0050 2D 30 30 35 2E 41 30 34 4C 46 00 00 00 07 27 18 -005.A04LF....'. 0060 30 9A 79 00 00 00 00 00 00 00 00 00 00 00 00 00 0.y............. 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 39 39 30 35 33 31 36 2D 30 30 35 2E 41 30 34 4C 9905316-005.A04L ------[ SMBus Device B00-D53 ]------ 0000 80 08 08 0E 0A 61 40 00 05 30 45 00 82 08 00 00 .....a@..0E..... 0010 0C 04 38 01 02 00 03 3D 50 50 60 3C 1E 3C 2D 80 ..8....=PP`<.<-. 0020 20 27 10 17 3C 1E 1E 00 00 3C 69 80 18 22 00 00 '..<....<i..".. 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 72 ...............r 0040 7F 98 00 00 00 00 00 00 05 39 39 30 35 33 31 36 ........9905316 0050 2D 30 30 35 2E 41 30 34 4C 46 00 00 00 07 27 18 -005.A04LF....'. 0060 30 98 79 00 00 00 00 00 00 00 00 00 00 00 00 00 0.y............. 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 39 39 30 35 33 31 36 2D 30 30 35 2E 41 30 34 4C 9905316-005.A04L ------[ SMBus #1 ]------ SMBus Type : nForce2/3/4/5/6 - Secondary SMBus Port : 6000 Can Have SPD: No Scan Type : Full ------[ SMBus Device B01-D2F ]------ 0000 C5 07 01 01 07 00 04 00 FF FF FF FF FF FF FF FF ................ 0010 FF FF FF FF 14 62 03 04 FF FF FF FF FF FF FF FF .....b.......... 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B01-D2F ]------ 0000 FFC5 FF07 FF01 FF01 FF07 FF00 FF04 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FF14 FF62 FF03 FF04 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Quote
Fiery Posted March 28, 2011 Posted March 28, 2011 Thank you for the data. We've fixed the sensor readings for your motherboard. Make sure to upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1339qs1d0nycgrzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
