vabchgent Posted June 19, 2015 Posted June 19, 2015 Any way to maybe use LPM instead of RPM For fan header . Most flow sensors use ML\m so LPM is basically same as the rotations maybe decimal places on the fan header tabs. In the LCD tabs or anywhere else that is self configurable. Example 3400 RPM =3.4 LPM This is valuable for flow sensors. Thanks Quote
Fiery Posted June 19, 2015 Posted June 19, 2015 I'm afraid it's not possible to alter the unit of calculation for fans. Regards, Fiery Quote
