TJ1990 Posted June 22, 2015 Share Posted June 22, 2015 Hello, I just discovered your program the other day and have been eager to use it for my Logitech G19 keyboards LCD display. Im half a noob with this stuff so bear (ahh!) with me please. I may be using this thread to come back for future questions when I get there. Ive been scouring the internet for hours today googling vague/incorrect results and luckily found this place!Here is my first question, I am trying to set up and I learned about templates, I found one I like but apparently needs it to be a .lglcd file. I saved the image as one, and I import it from my pictures folder. It does not show up in the pictures folder under .lglcd files so I choose all files and select it from there. The preview box remains as the background color however. I looked into the image properties and it reads as a .png file. What do I need to do to get this to work? Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 23, 2015 Share Posted June 23, 2015 Do not use the Import button if you build a LCD layout from scratch. Use the New button, or double-click in the list of LCD items to add a new item to your layout. Such an item may be an image file, a sensor item, graph, gauge, etc. When you have some items in your list, you can double-click on them to modify an item, and use the buttons like Move Up and Move Down to re-arrange the LCD items. 1 Quote Link to comment Share on other sites More sharing options...
TJ1990 Posted June 24, 2015 Author Share Posted June 24, 2015 Ok I see how this works now. Thank you! I didnt think to try importing the .png as an image but it works! Quote Link to comment Share on other sites More sharing options...
