Upgrade to Win10 and Chassis Fans disappeared
And I might just have remembered that in Win7 I was running the latest beta - I'll just load that up and see if the missing items appear again...
Well this is rather embarrassing - I loaded up the latest beta and lo and behold there they are again.
However I just lost my LCD arrangement that I just set up.
SensorPanel and LCD layouts are stored in the file called AIDA64.INI in the AIDA64 installation folder. Make sure to backup that file after you've built your LCD layout.
BTW, by using the built-in AIDA64 automatic internet update feature, both your settings (AIDA64.INI) and your entered product key (license) are retained after an upgrade.
Can you upgrade from AIDA64 normal to beta using the built-in upgrade?
Of course. You only have to (once) change the option Update type to "Stable and beta updates" in AIDA64 / main menu / File / Preferences / General. That will enable AIDA64 to look for both beta and stable updates, and install the latest one available.
Please note however that the built-in fully automatic update method is only available if you have a genuine license or use AIDA64 in trial mode.
