XplodZ Posted October 12, 2015 Posted October 12, 2015 Hi, I recently upgraded my computer to a Windows 10 64 bits. Unfortunately, Windows Gadgets doesn't exist anymore, so I can't use the AIDA64 Gadgets anymore, and I'm trying to create a new sensor panel (which is actually even better and way more customizable). The only problem I encountered was that even if I check "Prevent SensorPanel from being minimized", it still is when I minimize all the windows (Windows logo key + D). Is anyone in the same situation ? Is it a bug, or supposed to behave like this ? Thanks for any help I have a license of AIDA64 Extreme 5.50.3600 Quote
Fiery Posted October 12, 2015 Posted October 12, 2015 It's weird, since it works fine for me, under Win10 64-bit. Do you have any special window management software installed? Or any other software that may affect how windows are rendered or handled? Quote
XplodZ Posted October 12, 2015 Author Posted October 12, 2015 I found the solution, well I feel stupid for not having tried this at first, you simply have to launch as administrator and it's working... Thanks guys, this Sensor Panel is just perfect ! Quote
