P_R Posted November 21, 2015 Posted November 21, 2015 Hi, since a few AIDA64 version updates, Fan1 and Fan5 from aquaero are showing the same reading values (OSD). I cannot tell exactly anymore from which AIDA64 Version this issue has been introduced but I know that it was not there in the past. I created 2 aquaero dumps with different Fan1/Fan5 speeds and as reported Fan1 always get the same value as Fan5. I also tested if this was a problem with aquaero but HWiNFO is showing the correct speed values. It would be great if you could take a look at it. Thank you. If this is important, the Fans have following configuration: FAN1 -> Fans Radiator FAN5 -> D5 Pump 1 via Poweradjust1 aquaerodump.txt aquaerodump2.txt Quote
Fiery Posted November 27, 2015 Posted November 27, 2015 Please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Thanks, Fiery Quote
P_R Posted November 28, 2015 Author Posted November 28, 2015 Hi, with the new beta all aquaero fan sensors are now read/displayed correctly. Thanks Quote
