I have a samsung 87h 45 feet away in my tv room, so I can see process activity.
The unit also has an nmediapc lcd 2 line panel, which you do support in the front of the machine.  Do you support multiple panels?
Your proposed setup will work fine, since multiple panels of different kind is fully supported. What is only partly supported is having multiple devices of the same kind, like two Samsung SPF devices. Some of the device kinds are supported that way too, but some others aren't, so it's a case by case basis.
