Mikanoshi Posted December 22, 2015 Share Posted December 22, 2015 AIDA64 Extreme 5.60.3709 VCore and VID are the same on i7 6700K and both probably show VID (values are pretty high, 1.38V on stock 4200MHz, and they also don't match VCore in other monitoring programs). Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 22, 2015 Share Posted December 22, 2015 AIDA64 Extreme 5.60.3709 VCore and VID are the same on i7 6700K and both probably show VID (values are pretty high, 1.38V on stock 4200MHz, and they also don't match VCore in other monitoring programs). What motherboard do you have? I suppose it's not the one in your signature, which shows a Sandy Bridge system Quote Link to comment Share on other sites More sharing options...
Mikanoshi Posted December 22, 2015 Author Share Posted December 22, 2015 ASRock Z170 Extreme6 Don't want to update profile without overclock and benchmarks Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 23, 2015 Share Posted December 23, 2015 Thank you. The issue will be fixed in the next AIDA64 beta update due later this month. It will also add more voltages, like DIMM, DDR VPP, PCH +1.0V, VCCIO, and VCCSA. 1 Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 23, 2015 Share Posted December 23, 2015 The mentioned new AIDA64 beta update is available for download at: http://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works Quote Link to comment Share on other sites More sharing options...
Mikanoshi Posted December 24, 2015 Author Share Posted December 24, 2015 Thanks, it works perfectly now, all values match those in ASRock A-Tuning utility. Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 24, 2015 Share Posted December 24, 2015 Thank you for your feedback Quote Link to comment Share on other sites More sharing options...
