No Warning CMOS battery Voltage
redserv
Hello guys, I have a small problem that I am trying to figure out, I have AIDA64 installed on my pc and monitored separately
with a second screen, i recently noticed that the pc was not holding the correct time, My CMOS battery apparently died, however when i check my the CMOS battery voltage via Sensor Panel it says the battery is reading 3.360 volts, I know the battery is dead because i tested it and had it replaced, could someone explain why the sensor panel did not pick up it was dying? forgive me if this problem has been asked before, I am new to this forum and AIDA64 which i love.
Can you please check if the battery voltage is reported by the BIOS Setup? What value can you see there?
Maybe what AIDA64 calls battery voltage is actually the +3.3V voltage rail or the 3VSB (+3.3V Standby) voltage rail coming from your PSU (Power Supply Unit) ?
  • 1 year later...
