xplode Posted February 8, 2016 Share Posted February 8, 2016 The problem is that when i run both Aida64 and Corsair Link (i use the latest 4.2.0.132) Aida64 takes over Corsair Link settings and spin up my water cooling fans. I see nowhere in settings to stop this. This happen since Aida64 version 5.60.3748 and is present in the latest beta 5.60.3755. In Preferences => Stability there is option Corsair Link sensor support it does not matter if it is checked or not it still control my fans. If I uncheck Preferences => Stability => Low-level sensor operations the fans stop to spin up and down all the time and corsair link settings kick in and most of the temperatures are gone. Also i understand that in latest betas Aida64 utilize Corsair Link sensor information, but it is weird because when I monitor in Computer => Sensor Some of the displayed items (all readings from PSU - i have Corsair AX760i) disappear for few seconds then reappear then again disappear. Also another bug my pump is connected to CPU header on my motherboard but Aida64 does not display actual pump rpm for CPU fan but on older versions it was around 780 and in newer it is around 1400 and pump works on around 1800 rpm at the moment. The good thing is that in latest beta pump gets separate reading, but CPU fan still shows random rpm. This happens on Windows 7 Ultimate x64 with SP1, I haven't tested 8 or 10 but it will be most likely the same there too. Here are some screenshots of PSU disappearing problem: Aida64 5.60.3744 Beta Aida64 5.60.3755 Beta Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 8, 2016 Share Posted February 8, 2016 H100i GTX uses Asetek LC protocol, and not Corsair Link. So disabling Corsair Link sensor support will not make any difference. You can however set your configured fan duty cycle (%) in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Set Asetek fan speed to avoid AIDA64 altering the fan duty cycle to maximum (100%). The readings provided by the AXi PSU may be unstable because another software (besides AIDA64) is also polling the PSU for sensor readings, and that may collide with AIDA64 doing the same polling. Try to close every other monitoring software, including background processes. As for the CPU fan header, I suppose it should be related to the motherboard sensor logic, so please let me know what motherboard you've got, and we can start to investigate from there Quote Link to comment Share on other sites More sharing options...
xplode Posted February 8, 2016 Author Share Posted February 8, 2016 Thanks Set Asetek fan speed set to 0% solved the problem. As for CPU fan header it is possible that the Asetek cooler to provide RPM to motherboard header. About the PSU probably Corsair Link software is interfering with Aida64 for PSU reading, after killing it i have not encountered the problem. My PSU is connected to motherboard USB trough provided cable. Would you advise to enable In Preferences => Stability => Corsair Link sensor support ? Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 8, 2016 Share Posted February 8, 2016 My PSU is connected to motherboard USB trough provided cable. Would you advise to enable In Preferences => Stability => Corsair Link sensor support ? It wouldn't make a difference, since your PSU is not connected via a Link Commander unit. Quote Link to comment Share on other sites More sharing options...
xplode Posted February 8, 2016 Author Share Posted February 8, 2016 Thanks for your help, all problems solved here. Quote Link to comment Share on other sites More sharing options...
