Hi everybody,
I have a problem after a while I began to show wrong values in Aida. As shown in the picture.
It does not show me showing the name of the CPU. Bios on the board I have the latest.
Thank you for any advice :-)
PC: Spec >
Procesor: Intel Core i5 3570k @ 4,2Ghz / Noctua NH-D14 + 2xP14 | OperaÄná Pamät: Crucial Ballistix Tactical LP 4x4GB DDR3 1600MHz CL8-8-8-24 1,35V | MatiÄná Doska: MSI Z77A-GD55 | Grafická Karta: GIGABYTE N680OC-4GD | Zdroj: EVGA SuperNOVA 750 G2
Please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Thank you for the data. Something causes your CPU from providing incorrect (mostly zero) values for several internal CPUID and MSR registers. While other Core i5-3570K processors have no issue providing those registers properly. Without those registers it's not possible to detect CPU cache sizes and other CPU related properties that are necessary for our benchmarks to work properly.
Do you have any special virtualization environment installed? Or maybe you've adjusted something in the BIOS Setup that may be related to CPUID registers? Have you tried to return your CPU to factory default settings?
So between the time I try to install OpenCL for Intel CPU, as it was written in AIDE, it did not help. Then I threw the latest BIOS for the board. so also it did not help. CPU was def. settings. Really I do not know what he can defend. I desperately of it.
In your dump above your CPU is definitely not at default settings, since all Turbo Boost ratios are set at 42x there ;) Or you mean you've updated the BIOS and returned your CPU back to default settings after posting the dump above?
We happen to have the exact same MSI Z77A-GD55 motherboard (BIOS Version 1.11) with a Core i7-3770K CPU, and there everything works fine. Please make sure to have the option called Limit CPUID Maximum at its default state of Disabled in the BIOS Setup.
Everything works, thank you very much for counseling. I am very pleased thank you again  :rolleyes:
Then I suppose it was due to Microsoft Hyper-V ;) Which now got disabled due to the lack of hardware virtualization support ;)
