Phil Posted April 15, 2016 Posted April 15, 2016 Hey, i own Aida64Extreme for Windows 10 64bit. I've used it a lot the last months, but right now, without a change in hardware or software, aida doesn't work anymore. If i start the program, i see that "boot" Picture and the Icon in the Windows taskbar,. but i can't see the window itself. i can start a few tests with the infocenter Icon, but i'm unable to see the normal aida window. i did a fresh install of aida, but this didn't helped. greetings Phil update: if i Launch aida maximized, it works just fine. update....again: after launching it maximized, the windowed mode works again. Hope this is a permanent fix i think the Problem was my second Monitor. I've disconnected that Monitor a few days ago and i think the aida Window was on that second Monitor the last time i used it. So sorry for that new topic. Quote
Fiery Posted April 15, 2016 Posted April 15, 2016 Probably you've changed your Windows Desktop or monitor configuration, and that made AIDA64 display its main window on a position that was outside the visible area of your default Windows Desktop. AIDA64 has got an automatic mechanism to prevent that from happening, but maybe yours is a special case where it failed to fix it up automatically. If it happens in the future, just close AIDA64, start Registry Editor (via Run --> REGEDIT.EXE), navigate to: HKEY_CURRENT_USER\SOFTWARE\FinalWire\AIDA64 And remove all values that have a name the starts with Window Quote
