Hi, the DIMM sensor displayed in AIDA64 is not showing the correct sensor. I have been troubled by it saying the DIMM's were hitting 90 degrees when in reality they were in the upper 30's as they were warm to the touch. A bit of investigating with air spray and they a q-tip with the air duster liquid revealed it was this sensor at the back of the board where the exit vents are located.
Hopefully the right logs are attached :)
BIOS reports the correct temps for the DIMM's
Thanks.
sensorprof.txt
isasensordump.txt
smbusdump_full.txt
Thank you, we'll fix the issue in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new beta is available for download.
Good thanks, would it be possible to assign temp 4 as the DIMM please to match the BIOS readout?
Thank you for the feedback. Do you mean the temperature reading that is now (with the latest AIDA64 beta) labelled as Temperature #4 ?
Yes it is now temp 4. Thanks.
Thank you, we will rename Temperature #4 to DIMM temperature in the next AIDA64 beta update due in a few days from now ;)
  • 9 months later...
T
On ‎2017‎. ‎02‎. ‎15‎. at 6:30 PM, GoNz0 said:
Back again. Dell released the XPS 9560 and it has the same switched sensors again (confirmed by a couple of other owners). It seems a minor update, switch to kaby lake and GTX1050.
I attached the same dump files as before, hope it has everything you need or yell with whats next :)
Thank you, the issue will be fixed in the next AIDA64 beta update due next week ;)
The above mentioned new AIDA64 beta build is available for download at:
