flar2 Posted May 28, 2016 Posted May 28, 2016 I am missing PSU Power Value in the Sensor Icons, i can see it everywhere e.g. Rivatuner OSD Server, SensorPanel, AIDA OSD, or in the System Stability Test graphs, but it is missing as an option for the Windows Tray Sensor Icons. Quote
Fiery Posted May 28, 2016 Posted May 28, 2016 Sensor Icons cannot indicate electrical current or power values, due to limitations on the number of digits the icons can display. Regards, Fiery Quote
flar2 Posted May 28, 2016 Author Posted May 28, 2016 There are some items for Sensor Icons which do already use 3 digits plus a decimal point so i assume this could be OK for at least 999 or 1999W display reading if you wouldn't use any decimal point and also i assume there isn't much current values bigger than 99Amps. Quote
Fiery Posted May 28, 2016 Posted May 28, 2016 There are some items for Sensor Icons which do already use 3 digits plus a decimal point so i assume this could be OK for at least 999 or 1999W display reading if you wouldn't use any decimal point and also i assume there isn't much current values bigger than 99Amps. You're right, it would work if we implement conditional rounding of electrical current and power readings. It will be featured in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new beta is available for download. Quote
Fiery Posted May 30, 2016 Posted May 30, 2016 The above mentioned new AIDA64 beta update is available for download at: http://www.aida64.com/downloads/latesta64xebeta Let me know how it works Thanks, Fiery Quote
flar2 Posted May 31, 2016 Author Posted May 31, 2016 Working perfectly Idle and load power consumption now in tray-minimalistic yet doing it purpose so i don't have to use that clumsy Corsair Link app anymore. Also i like a lot that i can see the power consumption during gameplay using the RivaTuner OSD. Idle and load in screenshot. Quote
