fixed: GPU fan sensor discrepancy after wake from sleep (EVGA GTX 970 FTW+)
Hi,
Decided to uninstall/reinstall AIDA64 to try and address the SSD/HDD temperature sensor issue reported earlier. Not only does that issue still exist after reinstallation but there is a GPU sensor issue as well. Here are OSD items and OSD screen shots before sleep. Note that there is only one GPU sensor (PWM duty cycle) under Cooling Fans.
There is still the same lone GPU sensor under Cooling Fans after waking from sleep but now there is an extra GPU Cooling Fan item (RPM) showing in the OSD item list.
Couldn't paste the link for some strange reason, here it is in the attached file. Note that the GPU fan isn't active until GPU temperature exceeds around 65C. Had to run Furmark for it to show anything other than 0.
gpu.txt
