no1yak Posted August 6, 2016 Posted August 6, 2016 Hi, Can someone please tell me why my Asus Z170-WS board doesn't show any system fans( I have three) in version 5.75.3900 of AIDA64 Extreme. My other board Asrock Z 170 shows all fans. Everything else is shown including the Corsair fans and pump. Thanks in advance. Pete. Quote
Fiery Posted August 6, 2016 Posted August 6, 2016 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
no1yak Posted August 6, 2016 Author Posted August 6, 2016 Thanks for the reply, here is the two dump files ecdump.txt isasensordump.txt Quote
Fiery Posted August 8, 2016 Posted August 8, 2016 Thank you. We'll fix the sensor issues in the next AIDA64 beta update due later this week. I'll post a message into this topic once the new beta is available for download. Quote
Fiery Posted August 10, 2016 Posted August 10, 2016 The mentioned new AIDA64 beta update is available for download at: https://www.aida64.com/downloads/latesta64xebeta Let me know how it works Quote
no1yak Posted August 10, 2016 Author Posted August 10, 2016 The mentioned new AIDA64 beta update is available for download at: https://www.aida64.com/downloads/latesta64xebeta Let me know how it works Hi, Now showing two fans but two fans still not showing. . Quote
no1yak Posted August 11, 2016 Author Posted August 11, 2016 HW Monitor reports all the chassis fans but why is AIDA64 only reporting two. Any ideas ? Quote
Fiery Posted August 15, 2016 Posted August 15, 2016 We will fix that issue in the next AIDA64 beta update due later this week Quote
Fiery Posted August 18, 2016 Posted August 18, 2016 The above mentioned new AIDA64 beta update is now available for download at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works Quote
no1yak Posted August 20, 2016 Author Posted August 20, 2016 All Fans now showing in the lasted beta - for the upgrade. Quote
