Temperature of toshiba satellite l500d 163m300
george1703
 Share
Hello, I have the tosiva satellite l500d 163 m300. His recent change thermal grease and noticed the following: while the processor starts with 48 degrees Celsius and the gpu to 45, the fan of the laptop is not working. The fan starts just cpu catch 60 degrees. It is these normal temperatures; With a program to set up the fan starts from 50 degrees; I can also check if the sensors show the actual temperatures; thank you very much
 Share
