lewisd Posted October 27, 2016 Posted October 27, 2016 Hello, I've been using AIDA64 to show system information (temperatures, fan speeds, etc) on the LCD screen on a Logitech G15 keyboard. The automatic update I just did today seems to have broken the display of very small text. 6 and 8 point, in particular. Whereas before it was perfectly readable (using whatever the default font was, I don't know what it was set to) with the recent update, it's quite a bit less clear. The font now is Tahoma, though I don't know if the update changed it or not. This is how my fonts looked in August (the last time I took a photo of the LCD): http://imgur.com/VnLYPhE This is how they look after the AIDA64 update: http://imgur.com/kJmGUwP It looks to me like something in the update has drastically changed how text is rendered on the G15 LCD, and not for the better. Quote
Fiery Posted October 27, 2016 Posted October 27, 2016 Can you please export your current LCD settings (from AIDA64 Preferences) and attach it to your forum post, or upload it to somewhere on the web? Thanks, Fiery Quote
lewisd Posted October 31, 2016 Author Posted October 31, 2016 I've attached the settings to this post. 2016-10-30.lglcd Quote
Fiery Posted October 31, 2016 Posted October 31, 2016 Thank you. After upgrading to the latest AIDA64 version of 5.80, did you change anything about your LCD configuration in AIDA64 / main menu / File / Preferences / Hardware Monitoring / LCD / LCD Items? Did you change anything else about your Windows setup that may have removed the original font used before? I'm pretty sure it wasn't Tahoma before, since that font doesn't support font size 6. Do you happen to have a previous backup of your AIDA64 settings that may reveal the font used before? BTW, the update wasn't supposed to change any of your existing settings, including your LCD layout. However, in case the font previously configured was removed from your Windows installation (due to e.g. upgrading from Win7 to WIn10), AIDA64 may have reverted back to the default font of Tahoma. And if you change your LCD layout settings after that automatic font change, then AIDA64 would save Tahoma as the font into your LCD layout, effectively removing the name of the font that you used previously Quote
lewisd Posted November 1, 2016 Author Posted November 1, 2016 I did change a couple of the entries, trying to figure out what was wrong. But that was only after I already noticed it was messed up, after the AIDA64 upgrade. Do you know if there are any "standard" fonts that support 6 and 8 pt? I know it was a variable-width font before. I don't think I'd set a font specifically, I think I was just using the default? Did the default change or something? Quote
Fiery Posted November 1, 2016 Posted November 1, 2016 We haven't changed the defaults. The default font has always been Tahoma for the LCD module and SensorPanel. Try to set the fonts to Lucida Sans, it looks quite good at size 6. Quote
lewisd Posted November 5, 2016 Author Posted November 5, 2016 Weird. I have no idea what happened then. Quote
