Do I add CPU Package and CPU IA Cores under Power Values to know how much TDP/Power Consumption my CPU uses at X% load? Using CPU+FPU+cache for System Stability Test I'm getting a total of 189W (Package: 99W IA: 90W) at 4.5GHz 1.3v.
1 hour ago, Fiery said:
CPU Package should include GT Cores and IA Cores power.
Yes I realize that but I'm not doing any graphics testing so I ignore GT Cores just pure CPU tests and I have disabled my iGPU in my BIOS.
What I was trying to say above is that you only need to watch CPU Package power, since the other 2 is included in that value ;)
Ohh ok, thanks for the info.
