There seems to be no classic sensor chips in your system, or they're connected to an IPMI BMC.  Have you tried to check the Computer / IPMI page?  Maybe sensor values are reported via IPMI on your system.
I see no sensors on IPMI page, I did try HWINFO and I can see temps-added pictures for you.
I'm pretty sure I did see temps on Win 7 using an older Aida version but I can't remember more than that.
That look odd. Do you happen to have Low-level PCI bus operations or Low-level SMBus operations or Low-level sensor operations disabled in AIDA64 / main menu / File / Preferences / Stability?
19 hours ago, Toddel said:
No, all are enabled - all settings are default except show statusbar.
Thank you. That's rather weird then. Please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
