Jsunn Posted April 19, 2017 Posted April 19, 2017 Is there a way to display CPU Max Temp in the sensor panel? I see that you have it listed in the main program window for each temp monitored. Computer>Sensor It would be nice to have this value as a the sensor panel item. Thank you, -J Quote
Fiery Posted April 19, 2017 Posted April 19, 2017 It's not supported right now. You can however watch the minimum/maximum/average sensor readings on the Statistics tab of the AIDA64 System Stability Test. You can also use the Logging facility (AIDA64 / main menu / File / Preferences / Hardware Monitoring / Logging) to record the minimum/maximum/average sensor readings in a CSV or HTML log file. Quote
Jsunn Posted April 19, 2017 Author Posted April 19, 2017 Fiery, Thank you for the quick response. Maybe you can consider it as a new feature request. ;-) It would be nice to be able to glance at the sensor panel and see what my max temp was during my gaming session or rendering task. Thank you! -Jason Quote
Rafal6591 Posted November 3, 2025 Posted November 3, 2025 Hi Have you added max temp to Aida64 yet? Best regards Quote
