Problem with nvidia-driver 275.33: no GPU temps
hi,
since yesterday i have a problem with my g19 display.
there are not shown the temperatures from my graphicscard.
i try to install the graphicsdriver without aida64 is running. => problem is unsolved
then i deinstalled aida64 and install it new => problem is unsolved
hope you could help me
thanks!
installed the beta, sensors worked before restarting windows.
after restarting sensors are gone again.
version was v1.70.400
so i deinstalled aida and copy the files from the zip directly in the "finalwire" directory and restart windows again.
works! :)
current version of aida64 is now "v1.70.1426 beta".
p.s. using windows 7(64bit)
thanks for fast help! :(
