Jokesterwild Posted May 27, 2017 Posted May 27, 2017 I am probably missing something that is obvious, but using remote panel to an HTC 10. How do i get it to zoom so it fills the whole screen with the panel. right now I have it up on my phone but its tiny in the left hand corner of the screen! I tried googling to find a quick setting that I missed but had no luck! thanks! Quote
Fiery Posted May 29, 2017 Posted May 29, 2017 First, you need to configure the right resolution for your display (let me know if you need guidelines on how to do that). When you've done that, the LCD preview will show you the same layout that you can see on your phone. However, when the LCD preview layout only has the top-left corner populated, it is normal that it looks tiny on the mobile device. In which case you need to use larger font sizes to assure proper legibility on the smaller screen of the mobile device. Quote
