Hi everyone just wondering if there is a way to save all the settings for my Aida64 sidebar gadget? The issue that Im having is that all my monitoring items in my sidebar gadget are very slow to update sometimes not updating at all ie:cpu temps fan rpm etc dont seem to update even though I know they are changing, anyone know why this might be happening?
You can save the Desktop Gadget settings by backing up the AIDA64.INI file that you can find in the installation folder of AIDA64 (e.g. C:\Program Files (x86)\FinalWire\AIDA64 Extreme).
As for slow updates, make sure to check if the Desktop Gadget update frequency is properly set in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Update Frequency.
