I have a sensor I use that is always higher than 7 MILLION.  It is a NIC sensor.  Shows amount of kb/s
On the properties page, you allow a field called 'Show Unit', 'show value'
Can you add a 'Enable Conversion', whose item would be:
Divide by __  Multiply By __
In my case, I would divide by 1000, so it doesnt display like
10435, but 10.4
Units could be greyed out if a user does this or converted, but it would be cool to allow it.
When it comes to sensor items about network traffic, there's a neat trick. If you specify the unit as "MB/s", AIDA64 will convert the value to MegaBytes/sec.  If you specify the unit as "Mbps", AIDA64 will convert the value to MegaBits/sec.
